Old 03-28-2011, 05:03 PM   #1
Basically, most of the camber plate will have markings for the degree of camber.
Old 03-28-2011, 08:44 PM   #2
how does the one for the rear work though
Old 03-31-2011, 05:42 AM   #3
never mind I looked up how the rear one works but in a kind of related question. how mutch toe can I adjust with the stock eccentric bolt set up cos I wold like to zero my toe ,and even add a little positive toe. cos beond the eccentric bolt would I adjust it more with the lateral links if they make adjustabul lateral links right?
