-   -   88 rx7 camber adjustment (http://www.rx7forums.com/forum/showthread.php?t=2269)
Duneratz00 03-27-2011 04:49 AM
How do i adjust camber on my 88 rx7 i know to adjust the rear you have to buy those adjustable links but i have no idea how to adjust the front .and does ride hight affect camber at all
black rocket 03-27-2011 04:54 AM
I'd recommend taking it to a shop as they have proper tools to do it right.
Duneratz00 03-27-2011 06:37 PM
i took it to a shop all they could do is set the toe .so i would need to buy somthing to adjust camber right cos ill do the camber my self cos i want to put negitev camber on the front
BoostedFC 03-27-2011 09:45 PM
For the front adjustable camber plates, here is one option. There are other brands & distributors to look at, but you will get the idea.
http://www.horsepowerfreaks.com/perf.../Camber_Plates
http://www.horsepowerfreaks.com/view...=Camber_Plates
For the rear adjustable camber link.
http://www.corksport.com/blogs/73-ModifyFCPart2/02.jpg
Also look at corksports website
sidewaysFC 03-28-2011 02:28 AM
thank you super helpful info . im duneratz00's cousen by the way ive been using his account to post .im all set up on my computer now though
sidewaysFC 03-28-2011 03:31 AM
So how does the camber plate work, do they make it so you can move the top of the shock to adjust camber?
BoostedFC 03-28-2011 05:03 PM
Basically, most of the camber plate will have markings for the degree of camber.
sidewaysFC 03-28-2011 08:44 PM
how does the one for the rear work though
sidewaysFC 03-31-2011 05:42 AM
never mind I looked up how the rear one works but in a kind of related question. how mutch toe can I adjust with the stock eccentric bolt set up cos I wold like to zero my toe ,and even add a little positive toe. cos beond the eccentric bolt would I adjust it more with the lateral links if they make adjustabul lateral links right?
