Old 01-16-2006, 05:50 PM   #1
chrisg
Send a message via MSN to chrisg Send a message via Yahoo to chrisg
Default 88 Vert will not run
Brief Description of initial problem:
While driving I turned and car started acting like it was not getting fuel. Went about 1 mile and then it died. Waited 20 min and it started up but died after 1 mile. Waited 2 days and then drove 6 miles and it died and will not turn over. Going on two weeks and the following has been checked.
: Fuel filter, Fuel pump, fuel pressure, Control colum wiring harness, Fuse boxes BOTH. Main Relay good. Do not have the igniter checker which should be next logical step (I believe).
Questions: How do you check the coil igniter unit (trailing and leading)?
Can it be the Control Unit?
Please advise.
Desperate for assistance.
_________________
Pride Run's Deep. USN, Submarine Force
chrisg is offline   Reply With Quote
Old 01-16-2006, 07:47 PM   #2
Use multimeter and see if it's functioning.
You also might want to ck your grounding wires and while you're at it ck your vac lines.
How many miles do you have on your motor?
Old 01-16-2006, 08:52 PM   #3
chrisg
Got a tip from FAQ, just ran the check on the anti theft system. It failed all the recommended actions from the service manual. Could not get it to set at all. When I bought it the theft system was on and off. I quite setting it. Got water through the seals on the passenger side. I have 144,000 on the motor. Could the theft system cause this problem. It will turn over but not crank. No spark etc...
Thank you for the reply. Not much of a mechanic spent the last 20 years under the water. First project car. Although I have owned a 88 SE, 85 and 83.
Old 01-16-2006, 09:08 PM   #4
If in fact the theft deterrent is in effect your vehicle should not crank.
I think it's best to trobleshoot from coil on... when was the last time plug wires were replaced?
It may have too much resistance.
Old 01-17-2006, 02:33 AM   #5
chrisg
Verified Theft Det. system is BAD through trouble shooting procedure and with help from Vehicle / Nuclear/ Electrician (friend from Navy). Unplugged the theft control unit. Car turns over will not crank.
Also verified Coil has 12V out. Spark is making it to the engine.
Question: If theft Det. control unit is taken out of circuit can it effect the electrical control unit? Our thought is it could be telling the control unit not to fire? Scratching our heads. Might have to bite it and go to Mazda. No Mazda techs. outside of dealer in this area. Once again thanks alot for your suggestions.
Old 01-18-2006, 05:42 AM   #6
chrisg
Verified no spark at plug. Pulling the EGI computer to see if it is bad.
Old 01-18-2006, 10:18 AM   #7
No...Don't do the dealer, especially for electrical. If possible, trobleshoot it yourself. They CHARGE by the hour, you know.
Old 01-18-2006, 03:27 PM   #8
chrisg
Understand, I am a Navigation expert. No experience in electrical. Just checked their rates (Mazda). Wow. I am studying electrical at college and then will continue trouble shooting. Thanks for the reply.
Old 01-19-2006, 09:19 AM   #9
You're welcome...and many dealers aren't staffed with rotary guru either.
Old 03-03-2006, 12:41 AM   #10
SRTx781
Send a message via AIM to SRTx781
i have hte sema problem as well...when i try to crank the engine just turns over but wont crank and after 5 secs trying it smells like gas...i have 2 '88 RX-7's (both non-turbo) , one i know the engine isflooded..anyone have any comments on the "ATF" trick..in which i believe im supposed to take bottom SP's out then the EGI fuse and try to crank it...then put atf in the botton sp holes and turn it over..again and again about 4 or 5 times..it's supposed to restore compression...?!!
SRTx781 is offline   Reply With Quote
