05-17-2005, 11:26 PM
mods for a rx-7
I just got a 1998 rx-7 turbo and i have no idea what to do to it. So i was searching the web and found this site, so i thought i would ask you guys what your suggestions are on what to do to the car. The only goal i have with this car is to be able to beat a stock sti? I was thinking about upgrading the turbo to a t70 but im not sure what else i should do ex. ecu, fuel injectors and exc. Thanks for your help
05-18-2005, 12:00 AM
It is a typo...right? 1988.
It's all depends on many factors; reliability mod... would be an ideal for daily beater to performance mod...
05-18-2005, 01:52 AM
Oops, sorry for the typo, yeah you are right its a 1988.
05-18-2005, 02:09 AM
05-24-2005, 05:08 AM
BOV, FMIC, fuel managment, bigger snail, bigger charge pipes/DP/exhaust, upgrade the LSD, new suspension
05-24-2005, 08:15 AM
Yeah...you can always get bigger turbo but, bigger the turbo...more of turbo lag you'll experience.
First mod should be intake and exhaust. Simple and reliable.
After that, grounding mod, replace your vac lines, then go on to fuel mods, then, internal.
And, as I mentioned before...it's all depends what you want your FC to be!
05-25-2005, 05:06 AM
does anyone make like a turbo manifold for fc's?
1993 Ford Probe GT ATX to MTX swap
White w/ blue racing stripes and lots of little things
wanting a 2nd gen rx7
06-02-2005, 09:23 PM
Location: Looking At Your Headlights in My Rearview Mirror
88 N/A
THE GOD'S MADE THE RX7
This is Not My Car (below)
08-31-2005, 03:51 AM
#9
HKS makes a cast manifold that is acually worth the money. I think it is like 400 i think. But it will hold up better than a tubular. The only reason that is is because the welds on a tubular tend to break.
09-01-2005, 07:00 PM
#10
Yeah, I've got HKS cast mani... have it ceramic coate it, though.
I also heard about them tube mani being inferior.
