Old 09-07-2011, 04:22 PM   #1
booostin
Default found one i want, good purchase?
found a 1989 rx7 i want. its a buddies dads of mine. its garage kept, so exterior and interor is flawless. its got 60k original miles and everything is stock. says it drives fine with no leaks for anything. what are some common issues assciated with these cars? hes is asking $4k for it. good deal if everything checks out okay?
booostin is offline   Reply With Quote
Old 09-08-2011, 02:34 AM   #2
booostin
forgot to add, it is a convertable. and is n/a
Old 09-08-2011, 04:16 PM   #3
LunchboxCritter
That is not a bad price, depending on what your planning to do with the car. All USDM convertibles are NA.
It can be swapped over to a Turbo setup fairly easily.
A rebuild with a stellar port job and supporting bolt ons (ecu upgrade, injectors, exhaust, intake, etc.) can easily increase performance as well.
LunchboxCritter is offline   Reply With Quote
Old 09-09-2011, 06:26 AM   #4
Dozer
Send a message via AIM to Dozer
Sounds like a good buy, Just pick up a oil metering pump (OMP) just in case.
Dozer is offline   Reply With Quote
