03-05-2011, 08:37 PM
Suspension Suggestions
I just bought a 91 RX7, and the front springs are shot. I figure I will do all 4 corners of the car with springs/struts/shocks. What I need is suggestions. This vehicle will just be street driven, not raced.
Your suggestions would be helpful.
03-06-2011, 05:16 AM
A set of Tokico Illuminas with some Eibach springs will be a decent set up to run. Nothing over the top & will give you a little adjustability in the dampening.
03-06-2011, 08:17 AM
Good choice! Also, look into Racing Beat springs.
03-06-2011, 03:18 PM
Thank you! I am looking forward to better handling.
03-06-2011, 05:30 PM
Another thing to look into is the bushings. If they haven't been replaced Energy Suspension has a full line of suspension & chassis bushings. Then maybe upgrade the sway bars & buy a set of strut tower bars if in your budget & needed.
03-20-2011, 04:32 PM
Thnks for all of the help and suggestions. I purchased a Yellow Speed coilover setup, and hope to install next week.
