Old 02-08-2011, 04:33 AM   #1
rudy16
Exclamation electrical problems....
i have a little problem with no power going to the fuel pump. everything else works fine except for the pump. i dont know if its a relay or a fuse. i checked the fuse box and every fuse is working. but i dont know which relay is for the pump and i dont know were it is either. can anyone help?
rudy16 is offline   Reply With Quote
Old 02-09-2011, 10:44 AM   #2
The is a relay under the dash with a 4 prong connector & another under the airbox it looks like this.
Also If I remember the Air flow meter has a safety switch that when the flapper is closed the pump is off.
Old 02-10-2011, 01:54 AM   #3
rudy16
AWESOME!!!!!!!!!!!!!!!!! perfect! thks DD
