01-13-2011, 11:16 PM
Eccentric shaft pully qyestion.
I'm guessing you have to get the eccentric pulley bolt off before you can5 take the front cover off? How much torque is on it 350?
01-14-2011, 12:31 AM
Off hand not sure about the torque, but yes you will need to remove the pulley to pull the cover.
01-14-2011, 09:19 AM
Eccentric shaft pulley tightening torque is 5.8 - 8.0 lbs (shop manual)
01-14-2011, 09:05 PM
It was a stupid question lol but thanks guys
01-14-2011, 10:07 PM
Hey black I took my header off and a bunch of coolant poured out lol
01-15-2011, 12:02 AM
Coolant pouring out of exhaust ports is not a good sign.
01-15-2011, 12:07 AM
Should be interesting to see the inside of housings.
01-15-2011, 01:46 AM
Only thing that I can think of the scenario is coolant going thru TB may have possibly gone into the header as if there's a ruptured coolant seal coolant will blend with oil and both oil and coolant will burn ina working chamber. Residue will not even resemble coolant...
Let us know what you find upon opening the "pandora's box"!
01-15-2011, 03:05 AM
#9
Okay will do! I just now dropped the engine out! Now was size is that huge nut under the clutch? I couldn't find my measuring tape.
01-15-2011, 04:42 AM
#10
Its probably bigger than 10mm... LOL
Reason: Woops
