Old 08-13-2014, 02:23 PM   #1
marcanddulsie
Default tach jumps around
Can someone please help? 1985 rx7 gs and the tach jumps around when at idle. Once you press the gas the tach responds appropriately at the appropriate level. example. at 1100 rpm idle the tach will jump up to 3000 and jump between 3000 and 5000 will no increase in engine speed.
Any ideas how I could fix it?
It's just annoying...
marcanddulsie is offline   Reply With Quote
Old 09-24-2015, 04:15 PM   #2
rxwhat33
The tach runs off of a wire on the coil closest to the front bumper, clean both terminals on both coils to be safe and see if this fixes your problem.
Sent from my LG-D950 using Tapatalk
rxwhat33 is offline   Reply With Quote
Old 12-02-2016, 08:31 PM   #3
stanvanover
Also check alternator and battery
Sent from my SAMSUNG-SM-N910A using Tapatalk
stanvanover is offline   Reply With Quote
Old 04-11-2017, 12:48 PM   #4
rotorlife
Interesting ideas, I think it will help
192.168.1.1
rotorlife is offline   Reply With Quote
