FAQ If you have any questions about engine work, parts needed, part locations, anything....post it all here in the FAQ section! |
07-01-2004, 07:46 AM
what gas for your 7 ?
well you should run the lowest octane, because if you run a higher, you have the chance of building carbon which you dont want. i think.
well anyways, if im wrong Shaggy save the day and post it up.
07-01-2004, 08:37 AM
Administrator
Shit...I'm not the expert here...Ausy or ROTOR will tell ya..
07-01-2004, 08:43 AM
Member
N/A rotary engines are designed to run on lower octane gasoline, generally the lower the better, saves you money, and some people see better perfomance running lower octane gas in their N/A. Higher octane gas may not completely combust, leaving residue or creating problems with carbon buildup.
The opposite is true for turbo cars, because of the higher pressure in a turbo engine, you want to run as high as possible octane, to help prevent predetenation, damaging your engine.
I dont make much sense, someone else could do a better job clearing this up, but the rule of thumb i go by is, turbo needs high octane while N/A uses low octane.
07-01-2004, 08:46 AM
ahh yes, Tim. bout time you finally posted you homo :P
07-01-2004, 08:55 AM
Member
gimme a break, im tired and i feel fat from too much rice
07-01-2004, 08:58 AM
Administrator
Let me guess..you 2 are sleeping together...
07-01-2004, 08:59 AM
hey, you wanted more members, so i rounded up another rx7 wiz, but if you dont want us here, just tell us.
oh ya, we got a spot in our bed for you Shaggy.
I THINK NOT !!!!!!!!!!!!!!!!!!!!
07-01-2004, 09:09 AM
Member
maybe when im really drunk
07-01-2004, 09:11 AM
#9
no tim. no.
07-01-2004, 05:07 PM
#10
Administrator
Sick...
