Old 06-10-2004, 03:31 PM   #1
kyrx7
Send a message via Yahoo to kyrx7
Default turbo problem in factory twins
making 5 pounds of boost. but if let off the gas and let it blow off then give it gas it shoots to 12 pounds and runs strong. but will only make 5 pounds until you let off gas then give more gas. can anyone help
kyrx7 is offline   Reply With Quote
Old 07-08-2004, 03:01 AM   #2
marshall
Send a message via AIM to marshall
Sounds like you may have a vac. leak somewhere or possibly just running God awfully rich. I'd need more symtoms to really understand what you're saying. When you get on it at first at only 5psi, does the car spudder really bad and have a lot of black smoke out the back? stuff like that would help. Good luck with it.
It's only after you've lost everything that you're free to do anything.
marshall is offline   Reply With Quote
Old 07-13-2004, 04:21 PM   #3
MoReRyCe
Send a message via AIM to MoReRyCe
post a vid!!.. that would help greatly
MoReRyCe is offline   Reply With Quote
Old 07-13-2004, 06:24 PM   #4
marshall
^hah
Or we could all meet up at his house and listen and hear and see ourselves...
Old 07-14-2004, 11:19 PM   #5
It also shows a symptoms of bad control unit or circuit opening relay.
Old 07-15-2004, 03:42 AM   #6
2ROTORMOTOR
Send a message via AIM to 2ROTORMOTOR Send a message via MSN to 2ROTORMOTOR
more details please.... are you running seq??? are you running a manual boost controller??? anymods???
2ROTORMOTOR is offline   Reply With Quote
Old 12-20-2005, 08:10 PM   #7
kyrx7
i got this fixed finally took it to aim tunning in indy it was the pills was gone so i upgraded alot of stuff runs ok now
