3rd Generation 1993-Current Discussion |
07-09-2005, 04:50 PM
Originally Posted by Psycho_Dad
i believe the rule is 400hp from each rotor, so thats 800 MAX
best (only real way) to do it is,
upgrade your
injectors
ecu
turbo - gt35 or a to4e or somthing
turbo manifold
intercooler
fuel system
radiator to be safe
and thats about it, sounds easy, simple and cheap eh? go for it!
[email protected] if you wanna email me pix
good luck
cheers
Psycho_Dad
Big #'s is never cheap. And non of those turbo's will never give you 500hp not to mention 800. The upgrades you mentioned are essential for any turbo setup. As a matter of fact, those are beginner upgrades. When you want power, you are gunna have to run many custom parts. For that much power, breathing from the stock intake manifold becomes a big problem. Also custom exhaust manifold, you might even need to sump your oil. There are many things that you need besides the basics and they are plenty expensive.
custom exhaust manifold was obvious since you needed to go single turbo, as for hp figures i was talking about flywheel hp... would a gt35 really not make 600 flywheel hp? admittedly i was jumping in a lil early their, i should have researched more... intakes custom made wouldnt be that expensive to make would they? surely its the same basic principal as making intake manifolds? or would furthur porting the housings be required?
its all about learning from the gods(u guys)
oeace
Psycho_Dad
flywheel, maybe. But the thing is, that no matter how much you have flywheel,the one that counts is how much you gettin to the floor.
About the expense for a custom intake manifold. Ever tried to ask around how much is a custom exhaust manifold? When I was looking for mine, they ranged from anywhere in the higher $500's to the upper 9's someguy even quoted me $1k with 2 1/4" runners. Now, think about an intake manifold. There are people the sell the UIM, exactly like the factory one, except the ports are gasket matched, and they removed the acv and the water outlet for the turbo's. Those run about $600. So like I said, building and making power does take skill and alot of $. A gt35 turbo is small. Power will have to be in the 20-30psi for you to actually get close to 600.
07-09-2005, 09:48 PM
yeah what you need is kiwi enginnering skill and prices, americans allways pay american $ for things
eg: i can get a decent well made turbo manifold for a 4age(4 runnner) very professionally built and all for like US$300, or i can get a manifold made for my 13brew chevron(inwhich it needs to be extra long so the turbo mounts outside the car since theirs no room in it) which other engineers think this guy should be making exhausts for f1(ie: perfect) for $US500
im getting my axles shortened and resplined for $US50 per axle
if it were me, id be getting the uim built from scratch, if their is a problem with flow, theirs enough skill out here to make it so theirs NO problem with flow for less and 500. sure it wouldnt look pretty, but their wouldnt be a better flowing intake manifold made in the southern hemisphere
sorry i diddnt know flow rates etc of a gt35, ill withdraw that statement
thanks for the info 2rotormotor, im allways learning on the run
peace
Psycho_Dad
'it could be worse, a woman could cut your penis off and toss it out the window of a moving car....'
07-12-2005, 01:12 AM
my good friend own excessive autosports here in my hometown. so as far as the cost for the manifold would cost me about 300 he builds them, and full 4in mand bent exaust for around 300. the 600hp mark will cost me just under 10000 including the engine. im just worried cuz dont understand the rotary engine?? ya know.
holdn it down in south dakota
07-16-2005, 02:15 PM
the easiest and most reliable way would be a 20b engine swap with a single turbo conversion and a bridge port. at 600 hp that 13b wont last 5 min. assuming u were to boost the 13b to hell u still have to worry about lubrication remember on a rotary you have to deal with centrifical force the more rpms the more oil pressure you need to lube the engine. than you have to worry about cooling fuel octane housing warpage and amillion other head aches from my experiance 400 to 450 is the safest and most reliable hp #s for the street
1993 rx7 touring
1.apexi fc power comander
2.pettit clutch/short shifter
3.pettit intercooler
4.fluidyne radiator
5.greddy elbow
6.greddy chrome piping
7.k and N filters
8.greddy under drive pulleys
9.smog pump delete
10.17" enkei
11. 235/17/35 and 275/17/35 nitto 555
12.255 lph holley fuel pump
13.3" down pipe
14.3" exhaust piping with greddy muffler
15.brembo cross drilled and slotted brake rotors
16.eibach springs and tokico adj. shocks
07-23-2005, 10:24 AM
There is no need to bridgeport the 3rotor... 500hp is easily reached with stock turbos.... streetport is all you need to reach any hp goal, since you now have the added displacement..
08-07-2005, 05:00 AM
hey man, I found a stock 93 rx7 w/ 59,000 miles for $12,900. Is that a good price?
08-07-2005, 08:17 AM
No...
08-08-2005, 11:48 PM
if it isnt crashed the interior./paint/engine is good than hell yeah its a badass price
1993 rx7 touring
4.fluidyne radiator
5.greddy elbow
7.k and N filters
9.smog pump delete
10.17" enkei
13.3" down pipe
08-09-2005, 03:51 AM
#9
I can get 93's for 9 grand All day. 12 is already 94 territory.
08-10-2005, 06:25 AM
#10
I agree with 2rotormotor...
Besides, you might want to look for 94 instead.
