Old 07-12-2011, 07:52 AM   #1
ebeza
Exclamation turbo 2
im about to buy a 88 turbo 2 it has an idle problem engine starts up fine sounds good and no smoke. the rmp goes from 1000-1500 like it has a vaccum leak. i was wondering if it is that or if its something more serious? please help. and thanks for all the help i can get.
ebeza is offline   Reply With Quote
Old 09-03-2011, 03:57 PM   #2
LunchboxCritter
Sounds like a vacuum leak, tps needs adjusting/replacing, or even a bad seal. I would say if it passes a compression test then it should be a fairly simple and fairly inexpensive repair.
BTW: The car should idle at 850 rpm.
LunchboxCritter is offline   Reply With Quote
Old 09-06-2011, 06:28 PM   #3
mbonner
What shoukld be the compression figures for an 88 Vert, n/a motor? I have finally rigged up a compression tester for the rotary motor, but I forgot the acceptable numbers for a compression test,
Thanks,
mikey
mbonner is offline   Reply With Quote
Old 09-07-2011, 11:20 PM   #4
LunchboxCritter
It should be close to 100 psi or more on each face of both rotors. It is important that all 3 bounces on the tester be fairly equal. 80 psi and you need to consider a rebuild. Test at operating temp.
