Old 05-28-2011, 02:14 AM   #1
Well assuming that whatever got sucked into the motor didn't damage the rotors housings or irons, the rebuild should be straight forward.
Old 05-28-2011, 02:44 AM   #2
he's rebuilding it in the future but for now he has an engine thats just sitting in his garage that he wants to put in it.
Old 05-31-2011, 12:56 AM   #3
we took his engine apart last night and found out the problem one of the front apex seals broke in 2 places and screwed up the apex seal grove and put scratches in that rotor housing so the front roter and roter housing need to be replaced.
Old 05-31-2011, 12:59 AM   #4
plus we found that one of the water seal jackets broke and the water seal had failed wich is odd because it didnt show and signs of having a blown water seal
