Old 04-24-2011, 02:51 AM   #3
How did you check your compression? Did you have a rotary compression tool, use a piston type compression tool or did you pull out the plugs, and crank the engine over? (with the starter mtor not by hand) You should hear 6 nice strong even pulses. If they do not sound strong or even then there is some form of abnormal or uneven wear inside the engine.
