Old 04-14-2011, 06:54 PM   #21
You could spend the money on that chip thing then spend the money for the time on the dyno if you would like. Remember you will need to get a base line to compare to so before & after install of the chip on the same car. It also has a lot of claims you would need to monitor such as fuel consumption ect. Under the link I provided earlier on piggybacks & standalones there was a link to Jet performance. You send them the ECU & they will chip it then send it back to you. There a few other companies that offer similar services. Chipped ECU are very limited to what you will gain in return & are generally set to certain parameters with no alterations can be made.
Old 04-14-2011, 07:55 PM   #22
rx7Noobie
So its basically not even worth it lol, im not gunna bother w/ performance anymore racing beat headers & then a wideband & tune seem to be the only sensible thing to do
rx7Noobie is offline   Reply With Quote
Old 04-14-2011, 09:01 PM   #23
A full exhaust (header back), clutch/flywheel combo & a some sort of cold air intake is a good start. Try looking here they have some decent stuff. http://www.corksport.com/
Old 04-14-2011, 11:08 PM   #24
rx7Noobie
I just put on two new apexi n1 style mufflers w 3.5 inch outlit and i have my reg intake pipe into a 4 inch big k&n cone filter as a cold air
Old 04-15-2011, 05:50 AM   #25
Did you ever get any pics of the car so we here can see the progress?
Old 04-19-2011, 01:52 AM   #26
rx7Noobie
Nah i didnt =\ im waiting, some day this week me and my friend are gunna take our cars somewhere to take pics. Also ive decieded to re-do my exhaust because my friends exhaust broke off rite before the resonator and it made the cabin viberate alot after 3k rpms jus like mine does, i think i have a hole in my exhaust so im going to cut off everything before the piping after the y pipe that was just replace to my new mufflers, i believe the stock exhaust is 2.25" should i replace it w/ 2.25 or go to 2.5, im gunna put a high flow cat too (magnaflow)
Old 04-19-2011, 12:22 PM   #27
Nothing larger then a 2.5" if you do decide to change it & Maganaflow makes good products.
Old 04-20-2011, 05:52 AM   #28
rx7Noobie
Do you think ill Gain hp making it 2.5"? Also in the future im prob gunna get a 2.5" ebay header. Like this: http://item.mobileweb.ebay.com/viewi...id=30664278405 do u think with my cold air, those headers and a 2.5" exhaust w/ my n1 mufflers 3.5" tips ill gain some power? I also expect to backfire real nice >=]
Old 04-20-2011, 05:04 PM   #29
That header looks like a direct copy of the Racing Beat road race header. I'm just going to say this, with a complete exhaust & intake you will net some extra power, just don't expect a massive increase. They will allow the motor to breath better & are great starting points.
Old 04-20-2011, 06:22 PM   #30
rx7Noobie
Im not expecting a huge increase just any notable difference, & i jus need to get a 2 step after that exhaust n ill offcially have the most entertaining car lmao
