TECH Support Technical Support for your RX7, Open 24/7/365. Post your problems and see if someone can help! |
03-27-2011, 04:49 AM
88 rx7 camber adjustment
How do i adjust camber on my 88 rx7 i know to adjust the rear you have to buy those adjustable links but i have no idea how to adjust the front .and does ride hight affect camber at all
03-27-2011, 04:54 AM
I'd recommend taking it to a shop as they have proper tools to do it right.
03-27-2011, 06:37 PM
i took it to a shop all they could do is set the toe .so i would need to buy somthing to adjust camber right cos ill do the camber my self cos i want to put negitev camber on the front
03-27-2011, 09:45 PM
For the front adjustable camber plates, here is one option. There are other brands & distributors to look at, but you will get the idea.
http://www.horsepowerfreaks.com/perf.../Camber_Plates
For the rear adjustable camber link.
Also look at corksports website
http://www.corksport.com/
03-28-2011, 02:28 AM
thank you super helpful info . im duneratz00's cousen by the way ive been using his account to post .im all set up on my computer now though
03-28-2011, 03:31 AM
So how does the camber plate work, do they make it so you can move the top of the shock to adjust camber?
03-28-2011, 05:03 PM
Basically, most of the camber plate will have markings for the degree of camber.
03-28-2011, 08:44 PM
how does the one for the rear work though
03-31-2011, 05:42 AM
never mind I looked up how the rear one works but in a kind of related question. how mutch toe can I adjust with the stock eccentric bolt set up cos I wold like to zero my toe ,and even add a little positive toe. cos beond the eccentric bolt would I adjust it more with the lateral links if they make adjustabul lateral links right?
