Old 02-08-2011, 06:21 PM   #1
fnnuts86
Default 82 rx7 13b swap
I wanna swap my 12a w/ a 13b and I was wonderin what I would have 2 change in order 2 accomplish this my 82 is stock w/ a racing beat header
fnnuts86 is offline   Reply With Quote
Old 02-09-2011, 10:16 AM   #2
Well if you are talking about an 13b out of a GSL-SE, you either will have to do a carb conversion or obtain the ecu & harness to start off. If you are talking about a 13b from a FC you will need the above & a front cover from the early 13b for mounting reasons.
Old 02-09-2011, 06:58 PM   #3
fnnuts86
Id like 2 put a s5 but Im really jus tryin 2 get rid of carb . Im not lookin 2 get more hp than stock 13b . I kno ill have 2 change the header n thats covered racing beat has a 13b 12a swap header . N will I have 2 do ne fabrication like motor mounts drive train ect.op
Old 02-09-2011, 11:05 PM   #4
If just trying to move from a carb to EFI you don't need to swap the motor. There are are some great ways to do this. If you are set on the S5 swap get an oil pan & front cover from a S3 13b for the mounting. You will need to get the ECU & harness or make a harness for the control. You could also go with an aftermarket ECU to handle the control.
As far as ditching the carb in favor of EFI on the 12a here you go:
All you need with this is an IDA style manifold & an ECU
http://www.twminduction.com/Throttle...dy3002-FR.html
All you would need is a Holley style manifold & an ECU
http://www.efisupply.com/4bbl_throttle_bodies.htm
You could use your tranny, it should be fine at moderate power levels. I see you already know the 12 header will not fit on the 13b. Hopefully this helps a little.
Old 02-10-2011, 01:14 AM   #5
fnnuts86
Thank u but jus 2 make sure I understand u correctly all I really need is a s5 amd a few parts from an s3 what bout motor mounts
Old 02-10-2011, 01:18 AM   #6
fnnuts86
Or if I jus put a s3 n it
Old 02-10-2011, 04:04 AM   #7
You could do 13b with the EGI from the S3.
The front cover on the early model cars are where the mounts are & the mounts are on the oil pan & motor for the S5. That's why I was saying get the front cover & oil pan from the S3 13b.
Old 02-16-2011, 12:05 AM   #8
fnnuts86
You wouldnt happen to know where I could get a carb 13b at would you
Old 02-16-2011, 12:19 AM   #9
fnnuts86
Or even a turbo 12a
Old 02-16-2011, 02:24 AM   #10
Sorry man not off hand, check Ebay & try googling 12a turbo. you may find something for sale.
