Old 10-05-2010, 07:04 AM   #1
codey
Default fuel tank!!
when i get to bout half a tank the needle goes to empty..how do i fix that?
codey is offline   Reply With Quote
Old 10-05-2010, 04:16 PM   #2
You probably need to look at the fuel level sensor that is in the tank and replace it.
Old 10-05-2010, 10:06 PM   #3
Fuel level sender is easy to get to. pull the carpet back to access the assembly cover on the drivers side. Remove the cover & there will be another panel to remove to get to the fuel pump assembly.
