I think i have a flooding problem!!!
The only way i can get my car to start is to pull the egi fuse and crank the engine for 15 secs. i do this 3 times, and then the car starts but it has a really rough idle. if i dont put my foot on the gas slowly it dies. It doesnt matter if its really hot or cold, but it just suddenly happened a couple days ago out of the blue. I was told that the injectors might be leaking or a sensor might me bad, but i dont wanna pull anything apart unless i can afford to replace it, which right now is one part at a time After u get it running its perfectly fine, but if u turn it off and try to turn it right back on, even though uv driven for an hour, it has the same problem. Thanks for any help
