Old 12-31-2005, 08:07 PM   #1
FadedFD
Send a message via AIM to FadedFD Send a message via Yahoo to FadedFD
How many miles does your 94 have? Are you still running a stock exhaust system? It could be that you have clogged cats. I was having that same exact problem with my 93 R1 with about 115k on the stock cats and new motor and turbos with about 4k on them. Once I went high flow and DP the problem was gone. But big tip is get an aftermarket ECU so you can run those mods safely. A MBC is smart to keep it at 10 PSI. Make sure it dosen't spike since you don't have a fuel computer to compensate for the extra boost.
Justin
94 Chaste White FD TO4R
http://www.cardomain.com/ride/2224212
On MySpace.com? Check out the MySpace RX7 Owners Club
@http://groups.myspace.com/RX7
FadedFD is offline   Reply With Quote
