05-02-2005, 07:56 PM
where does it go?
where does the apex seal go? i don't even know where to put it. help me out. thanks
05-04-2005, 06:51 PM
Did you get the atkins rebuild video?
Turbo lag was created to give V8's a chance.
05-05-2005, 02:19 AM
Re: where does it go?
 Are you pulling our legs or what?!
05-05-2005, 02:55 AM
It looked pretty serious. CALL THE ROTA-POLICE!
06-02-2005, 09:29 PM
Location: Looking At Your Headlights in My Rearview Mirror
well the Apex seals go on your engine rotor. you need 6 seals for 2 rotors
3 seals on each rotor. the atkins video is good and so is a haynes manual. both of them tell you how to work on your car
well i hope i was some help
88 N/A
THE GOD'S MADE THE RX7
This is Not My Car (below)
06-20-2005, 06:53 AM
88 N/A
06-20-2005, 10:25 AM
Yeah...contact Atkins and say Black Rocket sent you
07-04-2005, 07:19 AM
dang i messed up again (ignore this)
07-04-2005, 07:24 AM
look at each point on the rotor and you will see a slit and that is where the apex seal goes and the spring goes under the apex seal so it pushes the seal against the housing acting similar to the rings on a piston
88 N/A
07-04-2005, 04:27 PM
I woulda deleted this thread from the very first post.
