How-To's Fixing your RX..and need some help. Check out the how-to's here for any help ya need!! |
06-13-2004, 12:42 AM
Member
engine rebuild
all im doing is porting, light wieght rotors, light wight flywheel.
 this is my problem i just want to know if any one has any ideas for me what to do and what no to do.
get sideways or get out
OWNED
06-13-2004, 05:57 AM
light weight rotors will have a lower compression number so you'll have to be boosting a shit load to compensate, and rpms will be redlining very fast with that set up. Usually they're only used for complete racing applications.
Make sure to get a mean ACT clutch to hold that down, otherwise you'll slip any time you put your foot to the ground.
06-13-2004, 02:07 PM
Member
so should i go with the light weight rotors or should i not cuz all i do in the car in auto cross and a little drifting...im planning on turboing it its a n/a now
this is my plan:
airinx intake
boost cut contorller
boost controler
hard piping
colder re spark plug
greddy front mount 2 row intercooler
t78 turbo kit with pulley kit
OWNED
06-13-2004, 03:03 PM
For autox it really depends on your style, I personally would rather have the normal rotors, a port job and intake, exhaust, upgraded fuel system, and boost controller should be good enough. Think twice before switching to a larger turbo for autox. Coming out of a turn do you want it to boost immediately with a fair amount of power or slowly with a lot of power?
I'll it back and wait for gsle to answer this thread, I do believe he is the resident AutoX expert.
06-13-2004, 05:48 PM
Member
hrmmm
thanks i never even thought over that
so r u saying keep it n/a and port
or should i just get a small turbo
OWNED
06-13-2004, 06:53 PM
I would get a TII.
06-13-2004, 08:32 PM
Member
hrmmmmm
im atculy looking for a t2 motor trans and wiring harness
and having no sucess
if u or ne body on the forums help i depspratly need it
OWNED
06-13-2004, 08:42 PM
Member
do u have aim?
cuz your link isnt working?
OWNED
06-13-2004, 11:15 PM
I do, and the link is fixed now.
12-01-2004, 02:51 AM
What do i do???
i have a 1982 rx7 just bought 13b turbo, what modifications need to be made?
