Old 11-25-2005, 09:20 AM   #1
general_macbeth
Default hesitation at 4000-5000
I have an 88 gtu with stage 2 porting. I have this issue where at 4000 rpms the engine hesitates for a moment, and then again at about 4800 rpms. Any suggestions? The only thing I can even figure is the secondary air intake port actuators are malfunctioning-but then wouldn't the hesitation only happen once?
general_macbeth is offline   Reply With Quote
Old 03-10-2006, 01:39 AM   #2
fc3s
Location: Looking At Your Headlights in My Rearview Mirror
have you checked your timing
88 N/A
THE GOD'S MADE THE RX7
This is Not My Car (below)
fc3s is offline   Reply With Quote
Old 03-10-2006, 07:01 AM   #3
TII
Member
Send a message via MSN to TII
It may be due to the grouding of the MAF, its a common problem often between 3800-4000rpm but it can happen at othere rpm's.
I think there is a FAQ in the stickied section about this actualy.
Best of luck
1984 GSL
1987 TII
1982 BMW 320i-T
TII is offline   Reply With Quote
Old 04-28-2009, 03:03 AM   #4
avafan
my car does this as well. these rotary engines aree strange. I have an 88 SE and just put tons of money into all the body work it looks brand new but i have clutch issues, stalling in corners issues as well as hesitation at 4000 rpms its pissing me off! I do know i have a air sensor disconnected that i need to reconnect its always been hanging since i bought the car and plus maybe i should check my timing.... If you find anything else message me please and thank you.
avafan is offline   Reply With Quote
