Old 06-25-2005, 01:12 AM   #1
robs_seven
Default Electronic Distributor vaccum lines
Problem 1
I have a 1979 12A mazdarx7 i have had it rebuilt by rotorsportsracing and i went to a electronic distributor so there wouldnt be a problem with the points floating, the only problem is i dont know where the vaccum lines go off the trailing part of the distributor, if any one could tell me where the two lines go i would apprecaite it
Problem 2
There is a place for a line that comes out of the oil fill tube, and a place that comes off the motor just below there, any one know what connects to the ports and where they might go. thanks for yalls help have a good one robert
robs_seven is offline   Reply With Quote
Old 08-28-2009, 08:57 PM   #2
63DH8
There should be a vacuum diagram on your hood. That'll tell you where all your vacuum lines go. If it's not there, find someone with the same year car and take pictures of both the diagram and the engine.
63DH8 is offline   Reply With Quote
