Old 05-09-2013, 05:25 AM   #1
Redconvertible
Default Need help
In need of help or ideas. I have an 89 RX7 convertible that I attempted to replace the factory radio in. Upon removing the radio from the dash and installing the aftermarket system I noticed the aftermarket system not functioning properly. I put the factory radio back in but now the car won't start. The battery is good and it starts to turn over but won't start. I thought it was flooded but have waited hours with no luck. My factory alarm won't set but if I unlock the car from the drivers side the security light flashes. Also when I remove the key from the ignition the security light flashes. Any help would be appreciated.
Redconvertible is offline   Reply With Quote
Old 05-10-2013, 04:51 PM   #2
Redconvertible
I had the battery checked and it was good with 100% charge, I'm getting fuel, and spark. The car still won't start. It is turning over but won't start. Any help or advice would be great.
Old 05-11-2013, 09:18 AM   #3
lamthao927697
- Trung tâm đào tạo và sát hạch lái xe THÀNH CÔNG
- Địa điểm sát hạch của các trung tâm đào tạo lái xe ô tô
- Sát hạch viên trực tiếp giảng dạy
- Học và thi ngay tại trung tâm - cam kết đầu ra
LH: 093.785.9665 - Minh Tú - pḥng tuyển sinh và đào tạo
lamthao927697 is offline   Reply With Quote
Old 05-11-2013, 10:50 AM   #4
lamthao927697
Old 12-05-2016, 10:18 AM   #5
marathonboats's Avatar
marathonboats
Send a message via Yahoo to marathonboats
I have same problem to solve
marathonboats is offline   Reply With Quote
