Old 12-31-2010, 05:17 PM   #1
Duneratz00
Default add coolent buzzer problem
today i want out and started my 88 rx7 up and like 20 secs after i started it the add coolent buzzer started buzzing so i popped the hood open the top coolent cap it was a little low so i toped it off . then i saw that my overflow was emptey so i filled it half way . then i started the car up and the buzzer went off again. it does have a small leek at the top of the upper rad hose , its been there ever sins i bought the car . please if any one knows how to fix this or has any ideas . i dont want to listen to that buzzer all day .
Duneratz00 is offline   Reply With Quote
Old 12-31-2010, 11:00 PM   #2
Just a shot in the dark, FIX the leak. The coolant level sensor may need to be replaced or not hooked up. Start there for now.
Old 01-01-2011, 12:46 AM   #3
Duneratz00
i just burped the cooling sistem and an air bubble came out and then it stoped
Old 01-01-2011, 07:29 AM   #4
Originally Posted by Duneratz00 View Post
i just burped the cooling system and an air bubble came out and then it stoped
Awesome! Good to hear
Old 01-02-2011, 01:46 PM   #5
Very nice, glad the issue got resolved.
