Old 04-14-2010, 10:59 PM   #1
jamesrcarney
Default Headlites
I have a 1985 rx7 ..the headlites will go up but dont come down unless done manually.Tried to see if there was a fuse but couldnt find it..Would anyboby have any idea as to whats going on..Thanks Jim
jamesrcarney is offline   Reply With Quote
Old 04-17-2010, 09:46 AM   #2
Adara
Needing to make some little adjustments on your car? We want to give you a hand to take care of them. In order to adjust a cars headlights, you need to find a good screwdriver to access the vertical and horizontal adjustment options of your lights without complications.
Adara is offline   Reply With Quote
Old 05-25-2010, 06:08 AM   #3
Patrick
Headlights are one of the most important parts of your vehicles safety prevention features. When headlights are dim, have failed or are not adjusted properly, there is a drastic decrease in the driver's visibility. It is essential to equip your car with adequate lighting so you can see and also been seen by others. The function and safety benefits are obvious, but the style and 'swag' could be what sets you apart from your compadres. The right set of headlights can provide the finishing touches on a car or truck you've sunk hours of your time into. Whether you prefer a euro-style carbon fiber look, one or two piece or even custom projector headlights with a halo-style surround, we carry a full line of high quality headlights.
We also carry head light and tail light covers if you prefer to with a 'stealth' look and black out your OEM lights. Clear protective covers are available as well, if you prefer to retain 100% stock look, but want to provide protection from the elements. Want something drastic? Try JDM Style Projector headlight with individual housing.
Patrick is offline   Reply With Quote
