Old 10-16-2009, 08:19 PM   #1
chrisnance
Default I think i have flooding problems! HELP!
The only way i can get my car to start is to pull the egi fuse and crank the engine for 15 secs. i do this 3 times, and then the car starts but it has a really rough idle. if i dont put my foot on the gas slowly it dies. It doesnt matter if its really hot or cold, but it just suddenly happened a couple days ago out of the blue. I was told that the injectors might be leaking or a sensor might me bad, but i dont wanna pull anything apart unless i can afford to replace it, which right now is one part at a time After u get it running its perfectly fine, but if u turn it off and try to turn it right back on, even though uv driven for an hour, it has the same problem. Thanks for any help!
chrisnance is offline   Reply With Quote
Old 05-10-2010, 08:57 AM   #2
Sounds to me like a common injector leak issue. You should ck and replace your injector seal. However, in order to access your injectors you must remove UIM and I recommend for you to have gasket ready so you can put them back together.
