Go Back   Rx7 Forum and Owners Club > Specific RX-7 Models > 3rd Generation
3rd Generation 1993-Current Discussion
Old 03-23-2009, 01:33 AM   #1
zzzpn1
Default car floods!! Help!!
My 7 floods everytime after I turn off the engine after using, as soon as I turn off the ignition it won't start. What caused it? please help!!
zzzpn1 is offline   Reply With Quote
Old 03-27-2009, 06:19 PM   #2
Jeromee
This is typical of Rx-7's in general, you must let the car fully heat up between uses otherwise the car will typically flood itself when you shut it off. One way to avoid this is to use a kill switch on the fuel pump. You will have to manually unflood the engine.
Jeromee is offline   Reply With Quote
Old 04-01-2009, 04:02 AM   #3
zzzpn1
I owned the car for many years, this is the first year that floods the engine everytime i use it even if I drive it for an hour when I turn the engine off it floods right away. Any other thoughts? Thanks guys.
Old 04-04-2009, 07:06 AM   #4
When was the last time you had your injectors cleaned? And also injector 0 ring?
Old 05-10-2009, 08:24 PM   #5
zzzpn1
After installing a kill switch, how do you manually unflood the engine?
Old 05-15-2009, 12:56 AM   #6
midnightrumble
you crank the car so the motor burns out the excess fuel, then turn the switch on and it should start
midnightrumble is offline   Reply With Quote
Old 05-29-2009, 01:29 PM   #7
zzzpn1
Thanks for all the help guys!!!
