Old 10-27-2011, 06:42 AM   #1
mrw000p
Default trans swap...?????
big question... do i need to change both counter weights when going from auto to stick...?????????
mrw000p is offline   Reply With Quote
Old 10-27-2011, 10:43 PM   #2
No & if you are intending on using a lightweight flywheel then you will want the rear counter weight from the auto. If not then get a rear counter weight from the manual. Leave the front alone.
