How-To's Fixing your RX..and need some help. Check out the how-to's here for any help ya need!! |
09-30-2010, 08:33 PM
Junior Mod
13b rebuild
i was searching for some info on rebuilding a 13b and came across this guys site, he has lots of good pics and information. its pretty lengthy but its addicting once you start reading it
http://grantboshoff.wordpress.com/20...ld-chronicles/
09-30-2010, 10:14 PM
There is a few great DIY rotary rebuild videos out there & all too many write ups for those who are interested in handling the build themselves. There is alot of great builders out there, I do suggest that you do a little research before deciding on one if you go that route. I say this because some people listen to advice of one person instead of really looking into the shop. I can not advise you there.
09-30-2010, 11:26 PM
Junior Mod
well i plan on doing a rotary rebuild over the winter and then a swap in the spring, i know that atkins has a good rebuild dvd, i'll probably pick that up along with a mazda shop manual as well
10-01-2010, 12:30 AM
Well appears that you have the right plan & a shop manual with the DVD would be a great investment.
10-01-2010, 01:50 AM
Junior Mod
is there a good place to find the shop manuals? or do i just have to seach ebay until one pops up?
10-01-2010, 05:47 AM
To be honest not sure I got mine from a friend at Mazda. I'm sure if you google it will be found.
10-01-2010, 09:13 AM
Shop manual is hard to find but, I heard CD one is available. Never looked into it so I can't tell you validity of it. And if you find one expect to pay $$$ for it. Its def a must if you do work yourself! In the meantime you might want to pick up Hynes just for gen reference.
10-01-2010, 06:36 PM
Junior Mod
i was also going to see if i could find one online, i had a couple PDF format manuals for my nissans...is there anything like that available?
10-01-2010, 08:28 PM
#9
Yes, they do.
10-01-2010, 11:40 PM
#10
Junior Mod
ok, i'll definatly check that out, my goal is to rebuild a 13bt-rew soon.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
