Old 05-12-2011, 02:47 AM   #71
Stay clear of the MK3 Supra they are heavy. 240SX's, RX7's & AE86's would be good choices for drifting.
BTW you are 20 & still in Highschool?
Old 05-12-2011, 04:19 AM   #72
rx7Noobie
Nah im 18 lmfao i put my age as 20 cuz i didnt wanna be treated like a baby but yeah idk i like the way the mk3 supra sounds =\ id get a turbo ii but then id have to worry about over heating problems and ae 86... =\ i want a nice clean looking car ae86's arent so sleek lol, unless i end up giving in to my love for turbo ii im prob gunna get an s13 and get kouki 180sx tail lights and do a silvia front end conversion and then just do a shit ton of work to the engine, it just sucks im only gunna be able to drive it the 4 months of nice weather we get in NY and the couple days of cold where theres no snow or rain =[, i also considerd a 13B TT silvia >=] that'd be sick seeing a silvia and hearing a TT 13B hahah
Old 05-21-2011, 02:23 AM   #73
rx7Noobie
Is the clutch fluid unde the hood top left resivoir? My car wouldnt go into gear for a while then my car rolled forward a little and my hand on the shifter dropped into gear... Also my friend got in my car when it was off and said i have no clutch n it barely engages..? Also when i hold the clutch pedal down when the cars running sometimes i hear a rattling noise kinda sounds likea cross with a tiny bit of screetching and change moving around in your pocket
Old 05-21-2011, 07:28 AM   #74
The reservoir is the little container mounted on the master cylinder with the line running to the slave cylinder on your trans.
You may have a bad release bearing, which you would need to drop the trans to access.
Old 05-22-2011, 11:14 PM   #75
rx7Noobie
And does royal purple sound ok for an oil change?, if not what do u recomend
Old 05-23-2011, 06:50 AM   #76
If you were to use synthetic oil, Royal Purple would be fine or Idemetsu.
Old 05-31-2011, 12:34 AM   #77
rx7Noobie
Is where u put clutch oil the cyldender type container at then top right of the engine bay like a foot right from the oil filter?
Old 05-31-2011, 05:52 PM   #78
It's the container on the clutch master cylinder not the one on the brake booster. Should say on the cap, do you have a shop manual or the owners manual in the glove box? Pretty easy to figure things out with them.
Old 05-31-2011, 07:41 PM   #79
rx7Noobie
Idk, i found a cylender shapped resevoir at the top right where i said n the cap said dot 3 only, and the resevoir was empty. my clutch didnt have much resistance at all and i barely made it to school, i asked my friend if he had clutch oil n he said brake fluid is the same and the cap said dot 3 which brake fluid says so by the time i got to school i barely made it, my clutch just was sinking to the floor n would sometimes stick, after skool i filled the resevoir and played with my clutch and got resistance back thank god.
Old 06-01-2011, 01:04 AM   #80
Brake fluid is perfectly fine in the clutch system.
