04-29-2011, 02:57 AM
#51
Yeah i jus got the header in the mail today, the only thing im not sure about now is if i should replace the rest of my stock exhaust to 2.5 inch piping, maybe my stock piping after the header an hi flo car is gunna be restrictive
04-29-2011, 03:37 AM
#52
You can if you want, but at this point it's not needed.
04-29-2011, 05:29 AM
#53
Niceee  i just hope after i put my header on it still has a deep tone. and im gunna wait on putting the header on till i get some money for heat wrap i guess, do you think its worth waiting for or does heat wrap not make much of a difference?
04-29-2011, 05:43 AM
#54
Heat wrap serves two functions. 1. Keeping heat in the header. 2. Helps with under hood temps & keeps heat off other components.
05-04-2011, 05:28 AM
#55
Update: waiting on my $200 to buy heat wrap n magnaflow hi flo cat...
P.S: with 160k miles on my 13b what do you think my chances are for blowing my engine going over 90mph if i take it to the track?
05-04-2011, 08:30 AM
#56
160k is a lot & any track time is added wear & tear so yes you would be increasing the chances. Not saying that it will let go, but going to the track os a situation where you pay to play. Sometimes things break or fail, so be prepared to fix.
05-08-2011, 12:41 AM
#57
I tryed ripping the ebrake in an empty lot and it doesnt lock up the back wheels it just slows it down why is this?
05-08-2011, 04:18 AM
#58
Possible that it needs adjustment! May I ask why you were yanking the E brake in a parking lot?
05-08-2011, 04:57 AM
#59
Trying to enter a drift, & idk i tightend the ebrake it still doesnt make the rear lock up -_-
05-08-2011, 06:12 AM
#60
Don't know what to tell you then. Should be working if the cable is adjusted correctly.
