Old 04-25-2011, 04:21 PM   #41
rx7Noobie
Lol jus checking, the stainles steel jus looks nicer lol, so when i get it should i wrap it in that heat wrap stuff before i put it on? And so yeah its pretty set im most likely gunna get this pacesetter its the cheapest price for what i need
Old 04-25-2011, 07:02 PM   #42
Nothing really wrong with the Pacesetter header, they come in a jet black coating & a polished. If you were going wrap the header now would be the time not after installing it.
Old 04-25-2011, 11:10 PM   #43
rx7Noobie
Header orderd , is it hard to install? Or just simple bolt on
Old 04-26-2011, 02:24 AM   #44
4 bolts on the flange to block & two bolts on the flange to cat. Old bolts may be a bitch to remove, other then that fairly simple.
Old 04-26-2011, 05:47 AM   #45
rx7Noobie
Alright sounds good, today i was driving and all of a sudden 3rd gear wasnt working id shift into third from second and it sounded like i put it into fifth but it wasnt accelerating the car... I had a small gap from the top of the short throw to the tranny so i tightend it all the way hopefully that fixes it or im gunna have to put bak the stock shifter -_- also is this good? Is titanium heat wrap ideal? http://item.mobileweb.ebay.com/viewi...id=75780336697
Old 04-26-2011, 06:47 AM   #46
Not sure on the shifter issue & the heat wrap seems fine.
Old 04-28-2011, 02:48 AM   #47
rx7Noobie
Also i think i read somewher theres a o2 sensor or some wire or something that goes in the header? Idk if thats for the 1st gen or what but i remember something about parts w/ a housing for a sensor
Old 04-28-2011, 02:54 AM   #48
You will need the header with a the O2 unless you feel like drilling a hole & having someone weld in a O2 bung.
Old 04-28-2011, 05:35 AM   #49
rx7Noobie
I think the pacesetter has it, it says it has "Hook-ups for smog and engine managment sensors"
Old 04-28-2011, 06:11 AM   #50
Then you will be fine.
