Go Back   Rx7 Forum and Owners Club > General RX-7 Area > How-To's
How-To's Fixing your RX..and need some help. Check out the how-to's here for any help ya need!!
Old 09-27-2004, 07:30 PM   #11
AusTexRex
Send a message via AIM to AusTexRex
N/A compression is higher, you're running a much higher risk of blowing your overly expensive turbo engine. Get a 13BT, port it, 3mm seals, monitor temps and fuel.
AusTexRex is offline   Reply With Quote
Old 09-30-2004, 12:54 AM   #12
Jinx
That's definately true, but notice how I said "If properly done" there is no reason not to turbo charge the N/A motor. But then again the same thing can be said for properly swapping a turbo motor in there, many people on many other forums are still hung up by this.
Turboing an N/A properly can be much cheaper than a full engine and tranny swap; and properly set up, can run just as well as a stock turbo motor.
*This is based on my opinion, research and experience only.
Jinx is offline   Reply With Quote
Old 09-30-2004, 02:48 AM   #13
AusTexRex
Granted everything is set up right you should be fine, BUT you better have a 40mm ported waste gate or something absolutely gigantic. One boost creep is all it takes on a higher compression motor to blow pieces of a seal right out the exhaust ports.
Old 09-30-2004, 06:35 AM   #14
Jinx
True true true. The need for a giant wastegate is grossly overlooked.
