Old 06-01-2009, 09:33 AM   #1
rockfordseven
Default no fuel :(
i have an 88 rx-7 and im not getting a signal to the injectors i changed the main relay main fuse and fuel pump but it rarely turns on but only for a few seconds i dont know if it could be the harness or the computer or something else
rockfordseven is offline   Reply With Quote
Old 06-17-2009, 05:44 PM   #2
teamn0kturnal
what rarely turns on.... the fuel pump?
common rx7 problem:
I dont know how you came to the conclusion that the injectors arent doing there job..... BUT I would highly recommend checking your AFM(hooked to the bottom of the air filter box) if it goes bad the car will start for a quick second than immediately stall, it cuts off the fuel pump when it doesnt sense airflow...
teamn0kturnal is offline   Reply With Quote
Old 10-21-2009, 08:34 AM   #3
turboII
tap your tank,probably just a short
turboII is offline   Reply With Quote
Old 10-27-2009, 04:02 PM   #4
vmerino
You can also locate a yellow connector in the engine compartment by the passenger's side and close to the pressure sensor. You can jump it and see if the fuel pump comes on. Good luck!
vmerino is offline   Reply With Quote
