Old 08-10-2004, 06:27 AM   #1
AusTexRex
Send a message via AIM to AusTexRex
hmm, try capping off the two ends to the BoV and plug the vac line. If that fixes it then it's your BoV. also try reaching in near the TB and pushing the throttle to idle and see if it changes.
AusTexRex is offline   Reply With Quote
Old 08-11-2004, 01:53 AM   #2
dub-c
Send a message via MSN to dub-c
how the fuck does a BOV effect runnning conditions ??? cancel that, im not in a mood too debate on stuff right now !
dub-c is offline   Reply With Quote
Old 08-11-2004, 04:02 AM   #3
AusTexRex
If it's leaking air dub. It's the same as any other vacuum leak. Aside from that if it's not vented back to intake then you'll run rich between shifts.
Old 09-30-2004, 12:32 AM   #4
Jinx
does it have the stock turbo inlet pipe? If so, pull it off and see if it's cracked right where it slips on the turbo.
Jinx is offline   Reply With Quote
Old 09-30-2004, 02:46 AM   #5
AusTexRex
That stock inlet pipe is a notorious piece of shit for leaks. However I think it's fixed, seeing as how old this topic is.
Old 09-30-2004, 06:31 AM   #6
Jinx
Gotcha.
Thread Tools
Display Modes
