Old 04-26-2011, 06:55 AM   #11
Nope not that I have ever heard. By changing the shape of the ports you can alter port timing & adjust the CAS.
Old 04-27-2011, 03:10 AM   #12
freddy junior's Avatar
freddy junior
that sucks but boostedfc maybe right thats way the back trail is staying wet if your going into it the motor u get whole rings and gasket kit and maybe bore her over or not by it be like new. Good luck. PS u can do it.
freddy junior is offline   Reply With Quote
Old 04-27-2011, 03:37 AM   #13
Can't bore a rotary, but you can have a company like Goopy Performance refurbish your housing if the the plating is flaking or gone. On another note if you pull the motor apart instead of finding a replacement, this would be the time to to consider any porting or any internal upgrades.
Old 05-02-2011, 06:03 PM   #14
shannonspeelman1231's Avatar
shannonspeelman1231
ok so im not leakin oil anymore i can get it to run if the intake is off but as soon as it put on it wont run wont start the oil i was leaking was coming from a bad pan gasket an i no longer have oil on the plugs i think i caused it when i put a vac line to the wrong place does anyone know where i can get a wirting harness at its electrical an i cant figure it out
shannonspeelman1231 is offline   Reply With Quote
Old 05-03-2011, 06:08 AM   #15
Not really sure what you are asking, I can't read your post. LOL
