i have a little problem with no power going to the fuel pump. everything else works fine except for the pump. i dont know if its a relay or a fuse. i checked the fuse box and every fuse is working. but i dont know which relay is for the pump and i dont know were it is either. can anyone help?
The is a relay under the dash with a 4 prong connector & another under the airbox it looks like this.
Also If I remember the Air flow meter has a safety switch that when the flapper is closed the pump is off.
__________________ Supercharged or Turbocharged, Boost is Boost
