Old 10-03-2010, 05:31 PM   #11
Well that's an easy fix so far. Slipped my mind really.
Old 10-05-2010, 08:46 PM   #12
Kfunk1989
No luck so far, drove it today and it still overheats... The shop said they'll do some pressure tests next to see if I have a seal leak.
Kfunk1989 is offline   Reply With Quote
Old 01-29-2011, 06:39 AM   #13
amosyuki
Originally Posted by Kfunk1989 View Post
I haven't noticed any white smoke, (its pretty obvious isn't it?) haven't seen any leaks, the coolant seemed really diluted and kinda gunky, but it has been sitting for a few years in a shed. The oil looked pretty clean, although old, and I had the coolant flushed and the oil changed. Would any leaks be obvious as well?
Thanks for the help!
Maybe you need some engine rebuild for it. since it its not the radiators, then maybe there is a bigger problem instead.
amosyuki is offline   Reply With Quote
Old 01-29-2011, 07:29 AM   #14
Hope that won't be the case. He'll find out with a pressure testing.
1986, overheating, rx7
