Go Back   Rx7 Forum and Owners Club > General RX-7 Area > FAQ
FAQ If you have any questions about engine work, parts needed, part locations, anything....post it all here in the FAQ section!
Old 09-28-2010, 09:03 AM   #3
Default Continued
Exhaust Scavenging and Energy Waves
Inertial scavenging and wave scavenging are different phenomena but both impact exhaust system efficiency and affect one another. Scavenging is simply gas extraction. These two scavenging effects are directly influenced by pipe diameter, length, shape and the thermal properties of the pipe material (stainless, mild steel, thermal coatings, etc.). When the exhaust valve opens, two things immediately happen. An energy wave, or pulse, is created from the rapidly expanding combustion gases. The wave enters the exhaust pipe traveling outward at a nominal speed of 1,300 - 1,700 feet per second (this speed varies depending on engine design, modifications, etc., and is therefore stated as a "nominal" velocity). This wave is pure energy, similar to a shock wave from an explosion. Simultaneous with the energy wave, the spent combustion gases also enter the exhaust pipe and travel outward more slowly at 150 - 300 feet per second nominal (maximum power is usually made with gas velocities between 240 and 300 feet per second). Since the energy wave is moving about 5 times faster than the exhaust gases, it will get where it is going faster than the gases. When the outbound energy wave encounters a lower pressure area such as a second or larger diameter section of pipe, the muffler or the ambient atmosphere, a reversion wave (a reversed or mirrored wave) is reflected back toward the exhaust valve without significant loss of velocity.
The reversion wave moves back toward the exhaust valve on a collision course with the exiting gases whereupon they pass through one another, with some energy loss and turbulence, and continue in their respective directions. What happens when that reversion wave arrives at the exhaust valve depends on whether the valve is still open or closed. This is a critical moment in the exhaust cycle because the reversion wave can be beneficial or detrimental to exhaust flow, depending upon its arrival time at the exhaust valve. If the exhaust valve is closed when the reversion wave arrives, the wave is again reflected toward the exhaust outlet and eventually dissipates its energy in this back and forth motion. If the exhaust valve is open when the wave arrives, its effect upon exhaust gas flow depends on which part of the wave is hitting the open exhaust valve. A wave is comprised of two alternating and opposing pressures. In one part of the wave cycle, the gas molecules are compressed. In the other part of the wave, the gas molecules are rarefied. Therefore, each wave contains a compression area (node) of higher pressure and a rarefaction area (anti-node) of lower pressure. An exhaust pipe of the proper length (for a specific RPM range) will place the wave’s anti-node at the exhaust valve at the proper time for it’s lower pressure to help fill the combustion chamber with fresh incoming charge and to extract spent gases from the chamber. This is wave scavenging or "wave tuning".
From these cyclical engine events, one can deduce that the beneficial part of a rapidly traveling reversion wave can only be present at an exhaust port during portions of the powerband since it's relative arrival time changes with RPM. This makes it difficult to tune an exhaust system to take advantage of reversion waves which is why there are various anti-reversion devices designed to improve performance. These anti-reversion devices are designed to weaken and disrupt the detrimental reversion waves (when the wave's higher-pressure node impedes scavenging and intake draw-through). Specifically designed performance baffles can be extremely effective, as well as heads with D shaped ports. Unlike reversion waves that have no mass, exhaust gases do have mass. Since they are in motion, they also have inertia (or "momentum") as they travel outward at their comparatively slow velocity of 150 - 300 feet per second. When the gases move outward as a gas column through the exhaust pipe, a decreasing pressure area is created in the pipe behind them. It may help to think of this lower pressure area as a partial vacuum and one can visualize the vacuous lower pressure "pulling" residual exhaust gases from the combustion chamber and exhaust port. It can also help pull fresh air/fuel charge into the combustion chamber. This is inertial scavenging and it has a major effect upon engine power at low-to-mid range RPM.
There are other factors that further complicate the behavior of exhaust gases. Wave harmonics, wave amplification and wave cancellation effects also play into the scheme of exhaust events. The interaction of all these variables is so abstractly complex that it is difficult to fully grasp. There does not appear to be any absolute formula that will produce the perfect exhaust design. Even super-computer designed exhaust systems must undergo dyno, track, and street testing to determine the necessary configuration for the desired results. Last but not least, the correct choices and combinations of carburetor, air cleaner, cam shaft, ignition, and exhaust used in the proper relationship to each other for the intended riding application will always produce the finest quality results. Most important of all, is to do your research prior to purchasing the combination of products and equipment best suited to your individual style of riding.
