Old 01-13-2011, 11:16 PM   #1
EastonH8
Default Eccentric shaft pully qyestion.
I'm guessing you have to get the eccentric pulley bolt off before you can5 take the front cover off? How much torque is on it 350?
EastonH8 is offline   Reply With Quote
Old 01-14-2011, 12:31 AM   #2
Off hand not sure about the torque, but yes you will need to remove the pulley to pull the cover.
Old 01-14-2011, 09:19 AM   #3
Eccentric shaft pulley tightening torque is 5.8 - 8.0 lbs (shop manual)
Old 01-14-2011, 09:05 PM   #4
EastonH8
It was a stupid question lol but thanks guys
Old 01-14-2011, 10:07 PM   #5
EastonH8
Hey black I took my header off and a bunch of coolant poured out lol
Old 01-15-2011, 12:02 AM   #6
Coolant pouring out of exhaust ports is not a good sign.
Old 01-15-2011, 12:07 AM   #7
Should be interesting to see the inside of housings.
Old 01-15-2011, 01:46 AM   #8
Only thing that I can think of the scenario is coolant going thru TB may have possibly gone into the header as if there's a ruptured coolant seal coolant will blend with oil and both oil and coolant will burn ina working chamber. Residue will not even resemble coolant...
Let us know what you find upon opening the "pandora's box"!
Old 01-15-2011, 03:05 AM   #9
EastonH8
Okay will do! I just now dropped the engine out! Now was size is that huge nut under the clutch? I couldn't find my measuring tape.
Old 01-15-2011, 04:42 AM   #10
Its probably bigger than 10mm... LOL
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
