Go Back   Rx7 Forum and Owners Club > General RX-7 Area > FAQ
FAQ If you have any questions about engine work, parts needed, part locations, anything....post it all here in the FAQ section!
Old 09-28-2010, 08:49 AM   #1
Default Nitrous "The Other Power Adder"
Most of the Faqs is stuff I pulled together from internet, putting it here just making it easier for our members to find.
Starting with the basics here, some of use it & some don't. Power on demand, boost in a bottle & best bang for your buck.
Q: What are the advantages of using nitrous compared to other performance options?
A: Dollar for dollar, you can't buy more performance with less money then that of nitrous. Nitrous offers tremendous gains in torque without having to rev up the engine to excessive rpm's
Q: Can I simply bolt a nitrous kit onto my stock engine?
A: Yes. NOS manufactures systems for virtually any stock engine application. The key is to choose the correct kit for a given application.
Q: Will nitrous affect engine reliability? A: The key is choosing the correct H.P. for a given application. A kit that uses the correct factory calibration does not usually cause increased wear. As the energy released in the cylinder increased, so do the loads on the various components that must handle them. If the load increases exceed the ability of the components to handle them, added wear takes place. NOS kits are designed for use on demand only at wide open throttle. Nitrous can be extremely advantageous in that it is only used when you want it, not all the time.
Q: How does nitrous work?
A: Nitrous oxide is made up of two parts nitrogen and one part oxygen (36% oxygen by weight). During the combustion process in an engine, at about 572 degrees F., nitrous breaks down and releases oxygen. This extra oxygen creates additional power by allowing more fuel to be burned. Nitrogen acts to buffer, or dampen the increased cylinder pressures helping to control the combustion process. Nitrous also has a tremendous "inter cooling" effect by reducing intake charge temperatures by 60 to 75 degrees F.
Q: Will the use of nitrous oxide affect the catalytic converter?
A No. The increase in oxygen present in the exhaust may actually increase the efficiency of the converter. Since the use of nitrous is normally limited to 10-20 seconds of continuous use, there usually are no appreciable effects. Temperatures are typically will within acceptable standards.
Q: Which is the best position to mount a nitrous bottle?
A: NOS bottles cone with siphon tubes, and in order to maintain proper nitrous pickup, is important to mount the bottle correctly. We recommend mounting the bottle at a 15 degree angle with the valve end higher than the bottom of the bottle. The valve end of the bottle should point to the front of the vehicle and the valve knob and label should face straight up.
Q: How long can I hold the nitrous button down?
A: It is possible to hold the button down until the bottle is empty; however, 15 continuous seconds at a time, or less, is recommended.
Q: When is the best time to use nitrous? A: At wide open throttle only (unless a progressive controller is used). Due to the tremendous amount of increased torque, you will generally find best result, traction permitting, at early activation. Nitrous can be safely applied above 2,500 RPM under full throttle conditions.
Q: Is nitrous oxide flammable?
A: No. Nitrous oxide by itself is nonflammable. However, the oxygen present in nitrous oxide caused combustion of fuel to take place more rapidly.
Q: Will nitrous oxide cause detonation?
A: Not directly. Detonation is the result of to little fuel present during combustion (lean) or to low of an octane of fuel. Too much ignition advance also causes detonation. In general, most of our kits engineered for stock type engines will work well with premium type fuel and minimal decreases of ignition timing. In racing applications where higher compression ratios are used, resulting in higher cylinder pressures, a higher fuel octane must be used , as well as more ignition retard.
