Model Comparision
I came here over 2 years ago and someone had a nice FAQ that had images of each model and year. What ones had LSD vs which ones didnt. Also the different opitions that came with the 2nd Gen RX7
I used the search function, searched for model comparision and didnt come up with what I was looking for. Is that page still around? I'm looking into getting a FC soon and want to plan out which model and year would be best Thanks |
well, what do u plan on doing to the rx7, if you want performance the best would be an s4 turbo2(87-88) because it has lsd and all the little goodys pluse you can run more boost with the s4 motor, if you want comfort and all the interior goodys go with a 91, just remeber the turbo has almost every option, and the gtu also has almost every option without the turbo motor.
Yeah, that sums up the most...S5s are also heavier than S4s and vert being heaviest of all.
Hmm
Well see the S4, S5 etc, I was hoping to look over the sheet. The FAQ's are ok here so i need to just read some more.
Most likely its going to be more of a DRAG setup, the engine isnt a big issue because I plan on doing a 20B swap on the car. Plus I like the car simple the more options the more stuff to break. I currently have an AE86 everything manual in the car so much easier to deal with. Where would be a good place to start to find out the difference in the S4-S6 models. I guess information compared to the bodies for those styles. Thanks |
Found my own answer
http://www.rx7forums.com/forum/viewtopic.php?t=53 I have plenty of time to read stuck at work later tonight. |
Re: Hmm
