86 rx7 and 93 mx6
the 86 is the project car and the mx6 is the daily driver, itsan 86 na and i was going to do the 13bre swap or 13bt? iam still not sure yet. my hp goals are 275whp. what should i do, i know i have to relpace all the drive train componets eaither way. idk iam lost right now. should i just sell the rx7 and race out the mx6, any direction would be helpfull?
Well, first, if you go with 13brew you'll have to modify your motor mount location. 13bt is more reasonable alternative to 13brew.
You still have to dump $$$ into your RX project as you will need a correct ECU and/or standalone. Axle length of n/a and turbo differs...so, you'll need to replace that. |
