-   -   CroSS ThreaD...NOOoooOOoo!!!!!!!! (http://www.rx7forums.com/forum/showthread.php?t=704)
blue_StrEak 12-28-2005 10:09 AM
i have a spark plug or moon plug that is cross threaded and is not in all tha way...wat should i do about it....could this be a reason for my car to bog a little....man i am really dumb.... :?
black rocket 12-28-2005 09:02 PM
You crossthreaded...you might be able to use same size tap and see if it works.
loosenut 12-28-2005 09:05 PM
or a thread cleaner just make sure to coat the tap or thread chaser(cleaner) with a light coat of bearing grease so the fillings stick to the tool and dont fall in the hole.
blue_StrEak 12-30-2005 03:36 AM
thanx for tha info fellas....i will keep that in mind while im doin' that....
