-   -   79 smog issue (http://www.rx7forums.com/forum/showthread.php?t=702)
carnut1 12-26-2005 07:50 PM
79 smog issue
I posted in the 1st generation site regarding a 79 rx7 running rich. Need some help with where to start assuming carb adjusted correctly and timing to spec. Some say thermal reactor worn out? plugged? Must correct this to pass calif. smog for transfer. thanks in advance.
black rocket 12-26-2005 08:14 PM
First, I'd recommend removing all the carbon build up in your engine by using ATF...which helps to burn fuel much cleaner and ck your cat and see that works.
carnut1 12-27-2005 06:25 PM
Thanks for the reply, but I'm told this 79 does not have a cat. converter but instead a thermal reactor? I will try the ATF but my car starts right up and runs good except for a slightly hunting idle 750 to 900 rpm. I'm told I can add a cat converter with no problem with smog board?
black rocket 12-27-2005 09:00 PM
thermal reactor... rx7 processes exhaust twice to meet (or come close) the emission issue.
Oh, yeah, installing a cat would help get you pass the smog.
