-   -   trany problem (http://www.rx7forums.com/forum/showthread.php?t=640)
Mouse 09-21-2005 11:48 PM
trany problem
I just bought a 87 rx7 turbo2. I did a full tune up and changed my trany fluid. my question is when i shift at low rpms it seems to shift fine. When i shift at high rpms it almost doesnt want to go in gear. it grinds and i let the rpms go down then I can shift. what is the best trany fluid? My friend said to use redline trany fluid. anyway if you have some info it would help greatly. thanks
my1stfc 09-22-2005 12:21 AM
personally i've had nothing but good experiences with lucas fluids. i would try that, but i don't think your fluid is the problem unless there is none, in which case you'll be lucky if that's all that's wrong. how's your clutch?
Mouse 09-22-2005 12:56 AM
I just replaced the trany fuid a week ago. and as for the clutch it seems fine. it doesnt slip or anything.
my1stfc 09-23-2005 07:35 AM
is the shifting problem with certain gears? some times, at least in my experience, the fc's have syncro problems. i can jam any gear as hard as i want but my second is a big prob. turned out to be the syncros.
Mouse 09-24-2005 03:22 AM
second gear is really hard and third is alittle hard but i think ill try some lucas trany fluid to see if it gets any better.
black rocket 09-25-2005 02:32 AM
Ck your shifter :)
DRFTFC3S 09-25-2005 08:06 AM
also try to see if ur clutch is slipping, go somewhere flat and put it in 3rd gear rev up to around 4k and release to engage clutch if ur rpm goes down ur clutch is fine, but if it stays up that means the clutch is slippin n worn out
Mouse 09-25-2005 05:16 PM
thanks for the suggestions and ill let you know how it goes. thanks guys
Mouse 09-25-2005 05:51 PM
DRFTFC3S I did what you said and the clutch is fine. Black Rocket what short shifter would you suggest. I am going to upgrade alot this winter . let me know thanks.
black rocket 09-25-2005 06:35 PM
Mazdatrix!
