Ignition Switch Removal...?
I need to take my ignition switch out to have a key made. I bought a car without one...
I took the column apart, no luck. So, I busted the fiberglass on top of the bracket holding the switch to the column. That was under the gauge bezel. I can get to the nuts (or whatever the hell they are) that are on top of the bracket, but I can't get anything to fit them and I can't look down there to see what they are. HELP! P.S. I searched for this already too... |
I'm not too familiar with FB but you probably needs to remove steering cover (covers steering rods).
I've also been looking for a Haynes manual or something locally, to no avail. Where can I get a factory service manual? I have the FSM for 89-91 RX7s and 93-95 RX7s... just not the FB. I got them online somewhere, I just forget where. |
You can always try Amazon.com to see if they have Mazda Shop Manual for yours.
And don't waste your money on Haynes or other manuals. You'll be much happier with mazda one. |
